Okay, I'm stuck. trying to remove the fuel tank from 88 graduate; i have drained as much of the fuel as possible; only slight puddle left. I have unhooked all the hoses and unscrewed the screws mounting it to the body, but the tank won't budge. i even tried using a jack with a piece of plywood to slowly try to raise the tank and give some upward pressure, but i still don't see any movement. It almost seems as though the rubber seal that it sits on has melted and acted as an adhesive between the tank and body. Has anyone else had this kind of problem? Any potential solutions out there?
