74 GTV with webers....did an engine rebuilt and don't see any oil pressure distributor spins my dash gauge worked before and now does not. I also did ground the oil pressure sender wire and the dash gauge went up to max. I even replaced the oil pump with a brand new one still the same. I also took the dummy red light oil sender switch off and cranked it and no oil coming out, so no oil pressure.
I am inside a garage with 40 degree temperature and using 30wt non-detergent oil, could it be the oil is on the thick side and the oil pump is not picking up?
I had cars parked outside before on a much lower temperature and the oil pressure was fine.
Any thought never had this issue before.
TIA
MK
TIA
MK
