Here is Alfaholics' take on the subject:
Alfaholics aluminium carburettor mounts
Over time, the original rubber mounts crack and leak air causing the mixture to weaken and consequently the engine to run roughly. Even the replacement reproduction rubber mounts have been known to crack prematurely and this has led us to manufacture these superb billet aluminium items for use as a direct replacement. They use premium quality rubber ‘O’ rings to form a perfect seal between the mount and the carburettor. These rubber ‘O’ rings, together with thackery washers (included in the kit), provide each carburettor with the necessary damping from engine vibrations. This ‘O’ ring set up is used widely for racing as it is considered to be the most effective and reliable method of carburettor mounting. The kit is supplied complete with studs pre-fitted in the mounts, ‘O’ rings, thackery washers and nyloc nuts. These are available in both 40mm and 45mm versions.*
NOTE: Alfaholics is selling these beautiful CNC mounts and therefore all superlatives should be discounted according, but the basic argument remains valid
Having said that, on my car I use the siamesed center rubber mount with the support rod. This ties the two carbs together and helps with both supporting them and keeping them from vibrating. Of course two single throat mounts are also needed. I've had no problems but mine are only a few years old and car really sees only fairly light use.
Double Carburettor Mount - 40mm
Carburettor rubber mounts - 40mm
i'll also that I agree with gpsprocket - don't even bother with the SPICA-manifold-to-Weber conversion kit. My car came with one and it never ran right until I dumped it for a full-Euro set-up.
Finally, if you already have a SPICA unit, it's not going to save money to properly convert to Webers. You can get a Wes Ingram SPICA rebuilt for less than the cost of properly converting.
