So my 2000 gtv door panels have lower holes for hardware that secures through the lower holes on the brackets behind the handle. Can someone shoot a pic of what the hardware looks like under the handle? Looks like there is a washer or something affixed against the surface of the door panel?
1649628
That door panel is not original.
`61 Giulietta Spider, `65 Giulia Ti 1750, `69 GT junior 1600, `73 Spider 2000, `74 GTV 2000, `98 156
Is that a US mod? My built `74 Euro spec 2000 GTV hasn`t got the screw and washer shown. That photo also shows a lot more securing screws around the edge than mine has.
· Premium Member
My 74 has brackets spot welded to the inside of the door that carry a 6mm floating 4 sided nut. The attachment fasteners are 6mm threaded screws set in the countersunk washers on the outside.
Discussion Starter · #8 ·
Thank you everyone! Your feedback helped lead me in the right direction at the hardware store today. Got the door panels installed and I'm another step closer to completion.
