In order to install the 2 L into my Giulietta Spider we used the sump from a 2 L Alfetta.
Need to know the length of the dipstick from the lower end to the flange as well as the measurements from the end to the min and max markings.
With thanks in advance:)
When I put the twin spark in my GTJ I used the GTJ stick because I used the GTJ Sump & Oil pump. Does that make sense? Ie if you used an alfetta sump & pump you would need the alfetta dipstick right!?
Don't know what I have now, but if I had an Alfetta dipstick it would be a plus.
Failing that--the measurements would help.
