Hello,
I'm having my 2.0 engine rebuilt for my 1974 GTV and would like advice/recommendation regarding a camshaft upgrade.
This is a STREET car and not a race or track day car. I would like to enhance performance on the street yet maintain driveability.
I plan to keep the Spica fuel injection system but have an expert rebuild and tune to match new cam.
Please advise on your experience.
Thank you.
· Richard Jemison
Camshafts
If you will send me an email I will send you full profile info of my cams designed for high torque and improved HP on Fuel injected engines.
I have designs including VVT applications with modified mechanical (VVT) units that advance at 2500-2750 RPM that can provide seamless torque /HP improvement from 1500 RPM through Redline or higher, depending on fuel availability from your FI system.
Rj
'74 GTV
I have Shankle 7L cams for In/Ex on my '74 2.0
They are nice down low in traffic and also give the car extra wind up high. Shankle is around no longer but you should be able to find a used pair or see if Alfa Ricambi has a set, as they bought Shankle's stock. Should be relatively inexpensive too.
· Premium Member
Alfa Euro "105.48" cams are old-tech and mild, but an easy, cheap upgrade compared to 105.20 or other US cams, that makes the car stronger everywhere by maybe 5%. Doesn't change its character, and works great with Spica.
