on a 2.0 motor,, the clutch assb. bolted to the flywheel a straight edge across the pressure plate fingers then measure the distance to the tranny/engine interface surface, thank you( in MM please :) )
Close to 80mm
Bianchi1,
The clutch plate fingers are slightly offset or countersunk from the pressure plate housing. Consequently, I was unable to lay a straightedge directly in contact with them. I was however, able to lay a straightedge across the clutch housing, measure down to the mounting surface on the block, and also measure down to the clutch plate fingers. With that information, the distance between the fingers and the block mounting plane could be calculated.
Here is what I came up with:
A = Distance from back of clutch housing to block mounting surface: 84.20mm to 84.24mm
B = Distance from Back of clutch housing to clutch fingers: 4.35mm to 4.37mm
Calculated distance from fingers to block mounting surface (A-B): 79.83mm to 79.89mm
