21 - 23 of 23 Posts
Lots of good information here... has anyone drilled or cut a hole in a Euro market repro dash to accommodate the flasher switch and seat belt light on USA models? Any red flags there? I presume the hole or cut out would go through sheet metal as well as the external plastic shell?
The Hazard switch hole was there on the one I got, but not the seatbelt one...which i did not install anyway. I did put A/C vents in and had to cut holes through t he dash and plastic. be very careful and I recommend that you cut just throught the vinyl on the front side and then cut the remainder from the back side where ever it will be visible...when youy cut from the front you can scar the dash...AMHIK
Thank you. Just the information I was looking for.
21 - 23 of 23 Posts
