I have checked with all the usual suppliers. Anyone have one to sell? I know its a shot in the dark as this is a 1 year only part. This is the shaft with the taper on the end and the wrap around spring. Its about 5.75 inched long. I was attempting to bleed my clutch and sheared the bracket off the end of the shaft, just like common on the hanging pedal units. I will probably end up rewelding, but would rather find a good part. Also, what material would be best if I had one fabricated? I have a good friend that operates a high quality (aircraft industry) water jet cutter and could use some scraps to fabricate a new part. He usually cuts using solid billet aluminum or titanium. Any help or input appreciated.
