Hi everyone,
Cleaning out the trunk of my newly-acquired S3, I've found a couple 'wires to nowhere' that I'm hoping to get some help identifying. I've included two photos - a scene setter, and a close up. Wire #1 has a 30amp inline fuse, followed by what looks like a ground connection. Wire #2 is a bundle that ends in a female plug. Although in the photo it looks like #1 and #2 originate from the same bundle, they enter the trunk via separate conduits. Any ideas?? I thought maybe the plugged wire could be for the optional window heater you could get with a hardtop, but not sure.
1604092
1604093
the 3 pin black plug is the power antenna.
your spider would have had one, but it seems it has been replaced with a non stock pull out antenna.
Okay, that makes sense. Was there a dashboard antennae switch, or would it have been linked to the radio power source? I'm guessing that the other mystery wire could have been for a parcel shelf audio amp of some kind. This car was also stripped of its AC unit and windshield washer tank. I found a used washer tank, but don't think I'll bother with the AC unit, especially here in VT.
antenna was linked to radio...no separate switch.
Depends on the model in the U.S. 1985 and earlier were not wired for a power antenna.
Gradute's did not have the power antenna. Spider Veloce and the Quads did. But many were replace with the manual one when the antenna mast was broken. A power replacement one was about 100.00 back then.
1986 to 1989 all models had the same wiring harness.
