Mystery Hose '72 2L
1602 Views 16 Replies 5 Participants Last post by  quadrifolio
So I've got this small hose hooked to my cam cover ventilation; it's next to the larger tube that used to go to the air cleaner. Where is the small hose supposed to connect?
thanks
Scott
1653868
1 - 17 of 17 Posts
It goes to the vapor recovery system in the trunk, if you still have one :)
Reactions: 1
The small pipe coming of the breather fitting that comes out at a 90 degree angle where to go down to the front of the inlet manifold.
Auto part Automotive engine part Line art Transfer case part Steering part
Reactions: 1
Thanks, I appreciate the info and picture.
I don't have a diagram to show you but if your car is US spec it connects to a tube that runs through the firewall, along the floor and in to the trunk. It sends gasoline vapors from the fuel tank back into the engine in order to save the planet.
Reactions: 1
There are four variations of the breather fitting that bolts to the cam cover.
1: It has the main breather hose and no small extra hose.
2:It has the main breather hose with one small hose at 90 degrees to the inlet manifold. That goes under to the front of the inlet manifold as in the diagram I provided.
3: It has the main breather hose with a small hose that runs parallel to the intake manifold the goes to the canister at the rear as part of a fuel vapor recovery.
4:Main breather hose with two small hoses. One at 90 degrees going to the front of the manifold, the second running parallel to the intake manifold going to the rear fuel canister.
The fitting the OP has was intended to go to the front of the inlet manifold as shown in the diagram I provided.
On early cars with the remote air cleaner the 90 degree small hose can also run straight back to the air box.
Alfaparticle if you are talking about a SPICA car I simply wouldn't know but would like to see a diagram so I can understand.
Ok, so Alfettaparts - I can't find any spot on the manifold to plug in the hose. I'm going to use a mirror and a light to look around just to be sure.
Ed - it's a 72 GT Junior that I bought in Naples, Italy a few years ago. It has a 72 or so 2L in it now that was also sourced in Naples.
So it probably has the wrong breather fitting. It should have no 1 where there are no extra small hoses.
If its any help I'm about to head into work. I can take some photos of the different fittings.
Thanks, that would be appreciated.
First two pictures are of inlet manifolds. One with the fitting, one without. The rest are variations of the breather that bolts to the cam cover. I think its pretty straight forward which ones match each other. I have no idea which car is supposed to have which ones with regard to originality. I'm lucky if I can remember my own phone number so I'll leave that sort of detail to someone else.
Auto part
Auto part Fuel line Engine Automotive engine part Metal
Pipe Auto part Metal
Auto part
Auto part Pipe Metal Steel
Reactions: 1
This may help:
Reactions: 1
Thanks, fellas. It looks like I can go ahead and plug the small fitting (or swap out to an assembly without the extra fitting), since there doesn't appear to be a corresponding fitting on the intake manifold.
Reactions: 1
You may want to consider a catch tank for the open breather.
I have one of the Alfaholics catch cans that I need to install. Want to do their pedal box first so I can see where I have room. Until then, I have a road draft tube that exits on the bottom of the engine compartment.
I verified that I don't have the fitting on the intake so I put a rubber cap on the other fitting. You can also see the temporary air draft tube I'm running.
1655204
take out the plug in the intake manifold with a flat screwdriver and plug it with a M7x100 screw and your done! it acts as an air leak in cyl. 1, so i plug it all times
1 - 17 of 17 Posts
