I've been trying to track down an odd coolant leak in my '86 spider. For the second time in the last 3 weeks I have come back from driving the car and notice a thin line of coolant on the outside of the hood, about center. Opened the hood and noticed some coolant inside of the hood (left hand - driver's side of hood). Just a small line. But can't find any evidence of where the coolant is coming from. The reservoir was still near max so it doesn't look like a significant amount. Looked all over the engine bay and everything looks tight.
Anyone have an idea where this might be coming from?
Last time I had the coolant system open was last spring. Had to replace the cooling fan after failure (engine mounts). At that time I also fixed a hole in the radiator caused by the fan coming apart. All the associated hoses were disconnected and re-connected - none are showing signs of leaks. Checked radiator and can't find a leak, hoses look good. We have put at least 1,000 miles on the car since then and haven't had an issue until now.
Any thoughts appreciated.
Had a loose clamp on the upper hose, and I as well looked & looked for quite a while. There was NO evidence anywhere. I never lost much, but there was always a stain on the hood after a long ride. Get a screw driver out and check the hose clamps! Mine didn't leak at first either.
Pressure tested the radiator before it went in. Have not checked it since installed.
Just checked all the clamps on the hoses. None were what I would call "loose" though I didn't like the upper hose was seated on the radiator so removed and re-installed, seems to look better seated. Have to give it a drive tomorrow and see what happens.
Pressure test the whole system. Many auto parts shops will loan you a pressure tester for free. The stock adapters in the kit will work fine for an '86 Spider.
