My car will only start with starter fluid.I read many post and now more confused then ever.I did the ground cleaning thing,new battery,checked the fuses.I can hear both pumps click on I cleaned the computer harness,I turned the key on while holding the relay and can feel it click.I looked for air leaks.I had the car running for awhile when I first got it and this happened so I cleaned some grounds and it started so I thought I had it fixed.Then I took it for a little ride and it died on me.So I think its a fuel thing.Can someone suggest what they would check or a list starting with the most common problem.Thanks for any help.I'm worried if I start ripping and tearing I'll just cause more issues
