This is my 3rd Alfa....need I say more? We are infected, but thats okay, my girlfriend collects plates with butterflies on them. I found this Spider in 2001 and have slowly brought her back just the way we like them. My goal was to create a reliable and still fun daily driver I could be proud of. I think I have just about replaced everything possible. Wheel bearings, steel braided brake lines, all tie rods and control arm and trailing arm bushings, Ward and Dean springs, Yellow Koni's, massive rear sway bar that goes under the diff from trailing arm to trailing arm with 195/60/14's, we started from scratch with the motor, balanced the crank and pistons, Hastings rings, drilled out the oil passages in the crank, yeah they were clogged, am using the Wes Ingram high performance pump, high perf valve springs with 10.6mm cams, tried the petronix set up with a bosch distributor but actually liked the Marelli Plex electronic system better, a two piece exhaust manifold from an earlier Alfa, no emissions, even tried running the exhaust with only the resonator, it sounded great, I mean ear to ear smiles great! and with out the rear muffler you could feel how much better it ran, but using better judgement I put an Ansa on, doesn't sound as fun but works. Everything in the interior I brought up to snuff, door panels, carpet from re-originals, and here's something I just discovered, are your lap belts looking tired? take a look at the Back seat seat belts in the 164...thats all I'm gonna say! And even the stereo is Alfa, and I was lucky enough to have a Mom back into me at a stop light, so that helped sport the cost for a bare metal respray, no rust or body work found at all, this is a solid car. And now a bunch of pics!! Check out my website too for more pics: Evan Klein Automotive Photography Automotive Photographer
