1 - 9 of 9 Posts
body form a 1979 bmw 320i ......drive dog, from a 1974 vw bug,, had to trim about 10mm off the shaft to fit the alfa,, easy stuff.., the dizzy is a point type dizzy, but i have a electronic inset driving the spark,, my msd 6l box, would not work with the stock 1984 motronic system, so hade to build a new system.. yes it has a vacumumn advance on it. keeping it for gas mileage.. the dizzy has been re curved to work with my 1984 spider.. a bit more aggressive.. i looked at the 123 and asst. aftermarket system, and figgerd this might work the best.. but i had my dizzy guy give me 4 diff curves( springs and weights)so i can play around a bit..
Looks nice, did you rebuild it too?
I had to laugh a little after looking at your .sig while thinking to myself "that must have taken some time!" :)
yes, i rebuilt it.. kind of dirty, so i cleaned it with paint thinner.. then got some 1000 wet/dry paper, and polished it up..
I've been wondering if it's possible to rebuild one if they start to get sloppy. I have never really inspected one, I do know the weights wore out on an old Marelli I had and would throw the timing everywhere.
everything (well, almost everything!) is rebuildable, but a lot of internal parts for these (weights, springs, bearings etc) are no longer listed by Bosch, so you might have to do some machining especially if the shaft bearing has play (checking the dwell angle usually shows up play in the bearing)
Someone like Glenn in the states restores Bosch dizzys (mainly for VW/Porsche) but he does mention Alfa.
Rebuilt Bosch 383 / VJ4BR25 / 010 / VJ4BR8 / 019 / VJR4BR18 / 022 / VJU4BR8 / "Big Cap" 40hp Distributors
Very cool. I still have a Marelli, but good to know the Bosch's can be rebuilt.
Discussion Starter · #7 ·
spider4.... you can get all kinds of weights springs of bmw.mbz, volvo's vw , and thing with a bosch dizzy..you just got to think ' outside the box ':)
good to know (especially as I am in Germany!!), and I do use the BMW/VW/MB/Opel forums here in searching for tips for others:)
I haven't any such "moveables" in my S4 dizzy so for now I dont need to worry.................:D but thanx!
Discussion Starter · #9 ·
some specs.. dynamic ignition timing ... degrees at crankshaft 25 btdc at rpm 2200 centrifugal control.at dgrees btdc 1000 = 3......1500 = 10....2000 = 19....2500 = 24....3000 = 28....4000 = 36......this is at static timing of 4 dgress btdc max per-igniton( without vacuum advance...degrees at crankshaft 39 +/- 3, this simlar to a bmw 1979 320 curve..
1 - 9 of 9 Posts
