While driving / cruising (70mph) on a straight (15miles) road, my car shut-off.
I had enough momentum to carry the car on the shoulder of the interstate. I had no warning or any symptoms, just out of the blue the car died.
While on the side of the rod,using my trunk tool box ( a must have) i was able to check the following:
Fuel pressure 32psi
Spark ok on all four plugs
fuse box ok
Battery voltage 12.4V
Fuel pump both running ok
Relays (main and Drive seem to work)
I even walked to the near gas station an purchased an" engine start fluid" but the car would not start when i sprayed the fluid in the intake plenum.
I am truly out of options, could anyone have better ideas?? I am tempted to think that the CPU is bad but I wish i could chake it before buying one. Inputs are really really appreciated.
Car is an 1985 L-Jetronic Alfa Spider
Thank you
Fuel pressure 32psi
fuse box ok
Thank you
