Greetings all!
My (new to me) '86 Spider got wet in the Nashville, TN floods last year. It appeared that the water reached not quite up to the door handles, not up to the instruments or over the top of the engine. Not high enough to get over the fuel filler. The water receded in less than 2 hours.
It was a nice restored 'weekender' at that time- a well cared for, garaged car in great shape. 70,xxx miles, it even has factory a/c. I got lots of (expensive) receipts and books with it.
The car was 'air dried'- opened up out in the sunlight, water was shop vac'd out of the carpets and trunk. There's no mold or mildew, just silt and dirt from the armrests down. A complete interior disassemble/clean will ensue.
Being the optimist I am, I thought I could handle the cleaning and thorough inspection of all that, and bought the car. I put a hot battery in this week to check things out.
All the power windows, radio, clock, gauges and warning lamps work. Headlights, brake lights, hazards, reverse lights work. Key buzzer works. I did drain/flush and refill the crankcase with a new oil filter- no water at all was apparent in the crankcase. I also removed and cleaned the Jetronic module and connections back there- it looked ok and not corroded/damaged that I could tell.
When I try to start the car, I only get a small electrical 'click' near/under the intake manifold. Like a relay or solenoid sound. I don't hear the starter engage at all, like it would with a weak battery. I've checked and cleaned the battery connections, they are clean and tight.
I did do some reading/searching on here before posting this, and did find a wealth of information. This is a great resource you guys have here. Thanks for tolerating my ignorance- I've worked on lots of other old cars, but this is my first Alfa!
Are there any suggestions for obvious things I should look for first in trying to start it?
