Mount Engine to Engine Stand?
8898 Views 12 Replies 9 Participants Last post by  tom shewchuk
I bought a used engine stand and I think I should have taken a closer look before I did. Is there some way to mount a Spider engine to a stand? I don't like the looks of the 4 studs that hold the bell housing on and I don't see any other threaded holes to attach to. I put a Ford 302 marine engine on a stand and it was solid as a rock but the aluminum block of this Alfa engine makes me nervous.
Thanks Much,
NH Rick
1 - 13 of 13 Posts
3
I cobbled up some spacers to bolt it to the side of the block - where the motor mounts attach.
I've seen plans for a adapter that bolts to the motor mount area. And a picture of one made with a piece of square tubing.
I was lucky enough to borrow a stand adapter from GTV4EVER.
Similar to the last picture above, it is made from a 6x6 tube steel.
It is 5" wide. Uses the adapter the stand comes with as well as the engine mount bolts.
Having trouble uploading pictures. Getting a message saying the max size is 700 x 0, whatever that means.
Good luck,
Vin
5
Let's see if this works.
Auto part
Latch
Technology Tape measure Electronic device
Ruler
Rust
Good luck,
Vin
This set up also provides a great shelf to use.
I put magnetic trays on both sides, so that no matter if I was working on the top or the bottem end, I had those trays to hold stuff.
It was great to have.
Auto part
Vin
Actually Vin, that picture was of the one you borrowed ��
Hi Ken,
Yes, that is the one I was lucky enough to borrow from you as said in post 3.
Do you have another?
Thanks again, it was invaluable!
Vin
Now that is a simple and effective solution to a stand adaptor !!
We rebuilt our spider engine last year using a cheapie engine stand attached to the transmission mating surface. I have seen most (all) Alfa engines are attached to the side (motor mount) area of the block.
Ours seemed to work fine bolting to the rear face
Either mounting system is fine and neither are going to drop the engine on your toes while you are torquing something.
I prefer the side mount because I like tilting the engine so the crankshaft axis is vertical for some operations. E.g., it's nice having the engine "nose down" when installing the front cover so the oil slinger is retained by gravity (I pre-install the oil pump to the front cover). "Nose down" also works well for installing the flywheel and pressure plate.
But the side mounting is a nice-to-have, not a got-to-have.
I used the bellhousing flange to mount to my engine stand. Here's a picture I took just before dismounting it from the stand.
Hi Ken,
Vin
I'm pretty low volume ?
One is enough
I used an old motor mount welded to a pipe that fit the stand. Angle the pipe so the motor mount is horizontal, then weld it to the pipe. reinforce the m0tor mount with a couple of tack welds.
1 - 13 of 13 Posts
