1 - 2 of 2 Posts
Many many 164 parts on sale now. NEW, NOS, RARE and USED. Don't see it? ASK! Marked down 100's of 164 parts on the site.
+ = many in stock
Blowing out tons of parts.
164 24V OEM brake booster/Master- NOS- $375.00 **SOLD
164 24V Intake air boot- $150 Qty 1
164 S/QV 12v Intake air boot OEM- 199.00 Qty 1
164 Heater Blower motor- BOSCH- $99.00 Qty 1
164 Q4 Rear rotors -OEM- $250 for the pair Qty 1 **SOLD
164 Q4 Rear Calipers-OEM- $300 for the pair Qty 1 **SOLD
Left front Door seal- OEM-$110 Qty 1
164 12V Front Rotors 71739568- $40 for the pair Qty 1
164 Wiper blade set- OEM- $37.00 +
164 BOSCH Headlamp Glass replacement Pair- $250.00
164 sway bar bushing- $3.00 each ++
164 Exhaust hanger- $2.00 each +++
164 Thermostats Behr w/housing- $81 each +
164 12V Front Right/Left Caliper Pair- $100 No core
164 24V Front Right Caliper NOS- $95.00
164 12V Brake Master Cylinder- $90.00 qty1
164 12V Clutch Master Cylinder- $48.00 +
164 12/24V Clutch Slave Cylinder- OEM- $75.00 qty 1
164 Floor mat set- $95.00 (black with red) qty 1
164 A/C Dryer Filter 60590126- $79.00
164 Rear Adjust Suspension Lateral Arm complete- $159 +
V6 Intake tappets – 60612178- $19.00 each ++
24V Hydraulic tappets –60664980- set of 4 –OEM - $128.00 Qty 1
164 12V USA- AUX Idler pulley- OEM -60513907- $80.00 Qty1
164 12v/24V Front Spring-NOS- $225.00 a PAIR **SOLD
164 24V Aux Belt idler- 60561615 - $99.00 each +
164 24V Aux Belt Idler Bearing ONLY (SKF ITALY)- $45 each +
164 24V LS/Super Intake runner boots- $28.00 each (6 on hand only)
164 Coolant tank Cap- OEM 46556738- $13.00 qty 1
“164” Rear Boot Badge- 60510718- $29.00
164 24V/12V Injector-NOS (GREEN) 5969614 - $125.00 qty1
164 24V “SUPER” Rear Badge- $20.50
V6 Rod Bearings- 60568882- RED/STD- $15.00 each half (8 only)
164 Front wheel Bearing- OEM-46421951- 79.00 (qty 5)
164 12V 1993> Resv. Hose to rear hard-line- 60571390- $40.00 (qty 3)
164 outer rear door handles- $50 each
164 Seat Motor-Back cushion movement- NOS -$50
164 Gas Cap- OEM (RED) 60575668- $29.00
164 12V OEM HEAD GASKET R/L - $59 each
164 24V OEM HEAD GASKET – $69.00 qty1
164 Auxiliary Belt Vibration Damper Pivot Bracket - 24V- 60561378- $189.00 qty2
164 Fuel Damper- 24V/12V-NOS 60567310- $40.00
164 91-93 Outer Mirror Switch –NOS- $90.00
164 24V Cam Gear-left-NOS- 60810655- $99
164 24V Coolant hardline between Heads- 60572266- $109 qty 1
164 24V ECU/w egr- NOS- 60565486 (Bosch ending in 287) $350
164 Rear veiw Mirror Control Unit-24V- NOS- $25.00
Oil Pan/Sump-1992-1995 (24V engines) 96412236 -$250.00 96412236
164 Hood release cable with grommets- 60555370 -$70.00
KING Bearings-ROD-SET Rod Bearing- V6 .020, - KING BEARINGS- $85.00
King Bearing Set Standard or (Red). - $149.00
164 OEM Windshield-Sekurit Heated- $799.00 + Freight
MORE...... On the site.
[email protected] or 619-209-0715
***This is nothing more than moving some items to you for a lower cost for your stock or repairs. I will be here for all your 164 needs. Please do not think otherwise. I have heard some rumors. Don't believe it. ;) ****
Discussion Starter #2
Since we cannot edit anymore. Dumb! Here is an updated list>
+ = many in stock
164 91-93 NOS Airbag with ECU - $60.00
ZF automatic transmission filter kit with seal- $70
164 NOS outer door handles- $55 each. Used $25 each
164 NOS 3RD BRAKE LIGHT FOR L/LS- $25
USED 164 early Inside door handles- $20 each
USED 164 12V intake runners- $15 each
USED 164 12V Crankshaft Pulley- $45.00 each
USED 164 24V auto instrument cluster- $50
12V- $40
USED: 164 Intermediate shaft- $50
USED 24V CV shaft complete 5 speed- $60
Used: 24V Center A/C vent- $40
Sides: $20
Used window assemblies front/rear- $35 each
Used door lock mechanisms for all 164s: $15 each
All door lock parts- call or e-mail
Used windows: $40 each, small rear $15 each
Used 164 HVAC blower motor unit complete (good condition)- $50
USED:
R/L Front fender 1991-1993 $50 each
** USED PARTS: NAME 3x PARTS FOR $25.00 IF I HAVE IT. (NOT THE ITEMS LISTED ABOVE) **
1 - 2 of 2 Posts
