1 - 9 of 9 Posts
Hi everybody,
I have still a lot of work to do on the 2600 Touring, but I start to repair the different function of the Monty.
First step, brakes :
I have dismount all pedal system parts (see pictures).
Auto part Suspension Automotive engine part
Do you know if repair kits are available for :
  • brake master cylinder
  • clutch master cylinder
  • and brake master vac.
Serge.
Push hard and live
What technique did you use to get the securing pin out of the pedal shaft?
Push hard and live
I'll try again, maybe with more heat. Bugger wouldn't budge when I first tried.
Discussion Starter · #7 ·
The pin may be blocked by rust (see my picture).
Give a strong blow to the head with a pin punch, being careful not to damage the thread.
By the way, somebody can help me => Do you know if repair kits are available for :
Discussion Starter · #9 ·
Hi Erik,
And thank you for the link.
Meanwhile I have made few investigation? My conclusion are :
  • brake master cylinder repair kit : Available :smile2:
  • clutch master cylinder repair kit : Available :smile2:
  • brake master vac repair kit : Not available :frown2:
1 - 9 of 9 Posts
