Thanks Rusty- I appreciate the offer. If the used hose is ok with no splits, I'll sure take it for now. Just message me and I'll get you my address.
Per IAP and Jon Norman of AlfaParts, this hose is no longer supplied. So, I'm coming up with an assembly that should fit into the space and I'll post the info and a photo when I get it put together.
Thanks again.
Sorry, I don't have the hose. My shaped hose from tank to filter was totally trashed, causing my car to stop running after about 5 miles. What I have is the fuel filter I took off with both sized nipples. I can't attest to its usefulness, but I can blow through it.
I replaced it with a fuel filter from NAPA, with the same girth, but two 3/8 inch nipples.
I used a 3/8 NAPA fuel line hose, cut it about 6 inches too long and looped it above the filter, to accommodate the otherwise formed original hose to prevent a kink. Used a grease to lubricate and hot water to soften the 3/8 hose and twisted it over the 1/2 inch outlet nipple.
I don't know how long the old oem filter will last, but at least it should last a while. You are welcome to it.
Using the currently available fuel filter for the spider, again,you need an extra length 3/8 hose (or the metric equivalent braided hose) to count for the lack ofthe 90 degree exit nipple on the replacement filter currently available.
To run from the filter to the pump, which has a 3/8 inch nipple.
Contact me off line,if you want me to send you my old filter.
Rusty
