1 - 12 of 12 Posts
Richard Jemison
I was going to post this on my "Technical Questions" thread but the new format doesn`t seem to allow a new addition, subject wise, to my ongoing thread???
I was sent a "rebuilt" set of Weber 45 DCOE 14s to update so they would work with a race level head built last month.
Oddly, these 45s commonly claimed to be GTA sourced, were choked to what appears to be 1300 Veloce specs (jetting) and internal components (the AVs and choke tubes.) The AVs were long thick AVs as commonly seen in 40 DCOE production carbs. Pics will be shown of the internals "IF!" the BB accepts pics.(Last post no??)
Whatever, pics show mods done to the Internal components and body of the carbs.
I can`t imagine that GTAs used such AVs. Regardless of runner diameter, availibilty of volumn properly atomized, into the manifold regardless of that manifold`s diameter, (relating to charge speed) I wouldn`t use such a AV.
These mods have been used in several customers race and very high output street motors. Similar mods to such AVs in 40 DCOEs have been done.
See pics of original parts modified to improve drivability and HP below:
Never mind can`t download pics!
FWIW stock GTA Stradale used the long thick wall auxiliary venturis with 30mm venturi - the whole intake was choked down ....
Richard,
email me the pictures and I will try to post them
Out of the office!
RJ, thank you for bringing this to my attention. I will ask that there be an enhancement so we can add subjects to our posts within a thread.
For now, I suggest the following:
ADD A TITLE LIKE THIS AS THE FIRST LINE IN YOUR POST
The tools they have given us are pretty useless. But for now, this is about all you can do.
Below the Post reply box, you can see B I U. Those are for Bold Italics Underline. Click the B and U before you type the title. After you type the title, click the B and U to turn them off.
Here are the missing pictures
Richard Jemison
Thanks Ed!
Actually the 4th picture was added by accident. It is a pair of 40 DCOEs that were similarly modified. Entrance is 48mm. You can see the additional clearance between the opening and the holes to mount the Airbox.
Richard have you tried clicking on the fourth icon from the left (the rectangle) and then open the folder there the photos are and dragging the .jpg or whatever file listing (not an open photo) into the box that pops up?
I have 45DCOE152's with 36 mm venturis that were modified by Richard as in the photos. When Jim Steck saw my dyno charts he thought that I was using 38 mm venturis. They really do flow very well.
1 - 12 of 12 Posts
