1 - 16 of 16 Posts
Banned
Here's a list of some more parts I don't need nor have the room. ALL are in very good to excellant condition with a couple exceptions like the windshield washer tank. Maybe somebody could use one. All are clean and inspected or I won't bother selling. Photos available, but aren't too clear as I'm on 'snail email'. The used parts are from low mileage '82 or '85 car. If there is a problem with an electrical part like the ECU, let me know as I cannot verify, but they were from running rusted cars.
Some parts can be used on other Models like the Milano. Buyer to verify individual use and ask any questions if you need to. Make a reasonable offer. Forums first , then eBay'm...Shipping (USPS preferred) is extra and per the instuctions Buyer. Combined is not a problem. All parts are in NE Florida 32656. PM or ring me at 904.210.9242 Bear with my response time as I'm traveling between jobs and may be sporatic on email access.
1. Bosch ECU PN 0 280 001 113
2. Bosch Ignition Box PN 0 227 100 017
3. Positive engine bay starter cable
4. Fuse Box - the wires were cut at the rear relays. This fuse box literally looks as new.
5. V6 Spark Plug wrench & container - no handle.
6. Alfetta new Brake Caliper Pins & Clip set. I think they're for the fronts and the pins are 65mm in length.
7. Alfetta/GTV6 Watts Linkage Rod End new bushing set - no center big bushing.
8. Windshield Washer Tank - all the holders are there; usual age discoloration; has a crack on the side corner and can be epoxy repaired.
9. 1 pair Front Brembo Aluminum Brake Calipers
10. New OEM Rgt Rr Tail Lite Lens
11. Front/Rear Upper Bumper plastic covers - 4 pieces. ALL the mounting brackets are intact.
12. Side Lower Skirt plastic body pieces - 4 pieces. These are the ones that cover the rocker panels. ALL the mounting brackets are intact.
13. Coolant Reservoir Tank - usual age discoloration. ALL the hose connectors and mounting brackets are intact. No visible plastic stress cracks.
14. I also have an '84 transaxle w/122k miles that's just re-sealed from my car. It shifted just fine and I used Redline Synthetic 75-90 NS. There's no clutch or input rod. I will post seperate if I decide to sell. With 3 different cars, the spares are starting to turn into a severe manic bipolar moment breeding with ADHD.
Those are a set of 4 out of the bushes needed right? So I would need theWatts Linkage Pivot Bushing. How much for the set, I am interested in Poly but a friend may need OEM. Thanks.
Banned
Discussion Starter · #9 ·
Ennio,
$20 USD + shipping of your choice for the 4 Watts end link bushings. PM me with the shipping & I prefer Paypal for funds.
jmhonnold,
The front Brembo calipers are still available. $85 + shipping of your choice. The calipers were working & not leaking at the time of removal. I'd suggest to just clean & re-seal them to new as they have been sitting for some time. I just did this to the ones on my car which are fine, so no need for another set. PM me for more info.
j
Banned
Discussion Starter · #14 ·
55,
I do have the 4 side skirts and they are in very good condition. They have all the conection tabs intact. I do not have any extra mounting clips. Cost is $20 USD each + shipping of buyer's choice; generally ground. Please notify me ASAP as I'm leaving town for over a month or more and I'll get them out to you. You can ring me any time at the # listed.
904.210.9242
Zip 32656
Any pictures of the skirts?
1 - 16 of 16 Posts
