1 - 1 of 1 Posts
Supporting Vendor
The Milano Verde had fender flares from the factory. They are not an aftermarket body kit but rather part of the Verde trim level.
Unfortunately, the way the flares are mounted they are essentially tacked on over the existing body work and that means they really don't provide any more room inside the wheel well.
If you have the right wheel offset you can run a 7" wide wheel with 225mm width tires fairly easily. However, they do have a tendency to rub in the front at full lock on *some* cars and not on others, depending on suspension and amount of lowering.
1 - 1 of 1 Posts
