1 - 2 of 2 Posts
I am about to replace the mechanical tensioner and belt and to bring the TDC is the following:
1- Crank pulley pointer on "p" mark
2- Distributor rotor on #1 cylinder wire
3- Remove plug on #1 cylinder and check with screwdriver the piston is up
4- For the camshaft to line up can you use the notches on the front cam pulley hub once you remove the plastic round cap correct?
Does anyone have a photo showing those markings on the cam pulley?
The markings are tiny, and may be hidden under grime.
1 - 2 of 2 Posts
