How do you remove and install a milano oil pressure pump? Does the sump need to be removed or can you get access with just the oil pan removed? Can you get access with the pan removed to get at the pressure regulation group to take out the spring and piston and clean them? Can the bottom part of the pump with the take-up screen be disassembled and put back together again while still in the car?Any info or threads would be helpful. Thanks.
