1 - 2 of 2 Posts
I lost all the instrument lights one night and the idiometer potentionmeter got really hot. I got a new dimmer but the system keeps blowing #14 fuse (7.5 amps). There are three wires to the dimmer. Yellow is power, but both black and white as well as black go directly to ground.
Before I shoot herion, does anyone know how the dimmer funstions or have any thoughts on troubleshooting. The wire diagram doesn't seem easy to trace.
Doug Bruce
87-Milano
The dimmer takes in voltage on yellow and outputs voltage on black/white. If you connect yellow to black/white the lights will work at full bright bypassing the dimmer.
In your case it sounds like black/white is shorted to ground. So the problem isn't in the dimmer, it's somewhere downstream of the dimmer on the lighting circuit.
1 - 2 of 2 Posts
