SOLD Barely used, this was supposed to be for my GTV6 3.0 24v engine, but I could not get it to engage consistently. Maybe because it's for a SOHC motor and the spacing just wasn't right. Either way, I went with the OE unit. 8 lbs lighter than stock. E-transfer or PayPal and you can message me here or [email protected] Retails for $660 US, Full specs here Alfa-Romeo-75-V6-760909AXG.html
1670813
1670814
1670815
1670816
The Brise starter requires a shim on the flange to work reliably. I posted about it maybe 2 years ago.
$200 is a great deal.
Won't work on an Alfetta, requires a totally different flange.
Angelo, I too had problems with a 24V starter and ended up going with the standard one. I sent you a PM.
I read the thread, it was one of the reasons I went with the Brise. I tried shims from .010 all the way through to .080. It was getting better by that point, just I wasn't feeling comfortable with the amount of engagement. It still wasn't 100% so I regrettably moved on. The Brise really is a nice unit though.
I used the Brice to give some clearance and leave room for a decent heat shield between it and CSC headers. Once installed it is MUCH easier to remove and install than the stock starter.
Absolutely, shimming or removing the Brise was much easier than the OE.
