Have a few questions re: rear suspension and gearbox mounts:
1. Refreshing the rear suspension and have already replaced the drop link bushings, but need a source for the stock 22mm sway bar bushings. Are these "split" so they can slip over the bar?
2. Is the GTV-6 rear gearbox mount pictured also the same for a Milano 2.5?
3. What is the name of the bushing pictured? See red arrow...
Using stock rubber, not poly...
1611237
1611238
Thanks!
Performatek - Alfa Romeo Polyurethane Bushings Part Number DDRARB-22
Yes they are split. Also his 25.4mm rear sway bar is highly recommended.
Yes
Generally called the de dion nose bushing, or pivot bushing. Available in rubber and poly. The rubber OEM bushing is very hard to install without the factory tool or a work around improvised tool
Hope this helps
Thanks!
1. Don't want poly, and am keeping the car 100% original; Vick Auto had a set of stock rubber bushings...
2. Good!
3. Thanks! Wasn't sure what it was called; will check with my mechanic re: installation.
