1 - 20 of 21 Posts
Question: where is it?! Not under the trunk carpet, and without completely removing the side carpets (as per manual although it doesn't say which side!) I haven't found it there either... Thanks.
On the top of the tank (which is behind the rear seat), in the middle toward the back. Is shown as such in the Fiat parts eper.
Thanks Del. So a quick exploration seems to indicate that the seat backs pop loose and can be removed? And that frees up the seat bottom?
Access is behind the carpet in the trunk. Pretty easy to get to. Take your time removing the plastic retaining clips. They break easily.
So the carpet that backs the rear seat backs? The section with the embossed plastic Alfa logo on it? Do the rear seat backs still have to fold forward? Thanks!
OK; so there must be a cavity behind the carpet. And I have plenty of experience with 30 year old plastic parts that break when you look at them!
I just replaced my tank a few weeks ago. I should have taken pictures. Once you get that carpet out, it will be very easy to see how it's all in there. Maybe half hour job total to replace that fuel sender.
My fuel gauge never registers completely full, even when I fill up the tank; only reaches about 3/4. I want to clean the leads on the sender first before considering other fixes...
The sender is extremely uncomplicated. The one pulled from the tank I replaced was so gummed up it couldn't move freely inside the containing tube. That may be the issue, which should be pretty easy to diagnose if you actually pull the whole thing out.
Discussion Starter #17
Looks like a check valve of some kind; I was able to remove the carpet (tricky if its your first time) and clean the electrical connector to the sender. The fuel gauge moved higher than where it was stuck at 3/4, so I'll keep an eye on it. How on earth do you remove the sender? There are no visible fasteners! Does it just twist off? I also replaced the 10mm braided cloth hose from the canister to the tank, and tightened all the clamps.
1626204
Sender is twist off. I had to use a rubber mallet and a long flathead to gently "help" the rotational force get started. There is a gasket between the sender and the tank that has a tendency to get stuck.
1 - 20 of 21 Posts
