OK I finally got to pulling the Verde's motor. I think I am pretty there.
Got past the digging into the head from the lifting point on the driver's side by using a 2X4 to spread the chain but will look into a load leveler. I went to pull the motor but the motor wouldn't budge. Should I have only disconnected the single nut on the motor mount or the bolts that attach at the body?
I have the unbolted three of the bolts on the donut but should I pull the drive line? I figured I could pull the motor forward but that may be that is what is holding up the motor..
Help? Thanks!
Help? Thanks!
