The electrical gremlins have struck again! This time it's the windscreen wipers. Problems: No intermittent function, and no stow (park) position when turned off. The wipers will work in the intermittent position, but they will not pause as they should for a few seconds between sweeps, nor will they park; the wiper arms will stop immediately wherever they are on the windscreen when turned off with the multifunction switch on the column. The low and high speeds also work fine, but they will not park either when turned off. The column switch is sending power to the wiper intermittence relay in the fuse box (which BTW is NEW, as I thought this surely was the fix, but alas, did not resolve the problems). Power is obviously going out to the motor from the relay as all three modes (intermittent, slow, and fast) all drive the wipers back and forth across the windshield. The windscreen washer mode also works as it should, but again, no park position. The shop manual troubleshooting section states either "replace the stopper" or "replace the motor" for the symptom of wipers not returning to the park position. There's no other mention of a "stopper" in the manual. I assume this "stopper" is likely a part of, or attached to, the wiper motor. My experience with wiper motors is that the park position is usually inherent in the motor circuitry. Meaning, I need another motor. Can anyone please confirm if there's a stopper somewhere other than inside the motor? I'm getting quite good at timing the sweep of the wipers with the off switch but this is my daily driver and it's a bit annoying.
