1 - 18 of 18 Posts
I purchased a set of 5 15" Speedline phone dial wheels to be refinihsed by Dave at Renewed Finishes in PA. This was before I learned that Benzoni also made the 15" phone dial wheels with a slightly different offset so I went and purchased a set of Benzoni wheels as well.
That said, I'm considering selling the 5 refinished Speedline wheels since I do not need both sets.
Jeff
If you don't mind me being nosy, how much did the refinishing cost? I too have a set of Speedlines and a set of Benzonis. Will eventually refinish the Benzonis, but it seems like the actual finish of the wheels is a bit better on the Speedlines (from the factory that is...both wheels sets are original).
bump with updated image links
This final image is of my Milano on Benzoini wheels that were refinished by Dave at Renewed
Jeff
Really beautiful Milano! What is that color?
The color tag at the trunk says Met Azzurro AR371
That said, this car has been resprayed and the color is just slightly off the original when you compare the color in the door jams.
Jeff
Supporting Vendor
Nizam, they are the 15x7, with a ~30mm offset if I am remembering correctly.
Jeff, your car looks amazing! What size of tires do you have, and is your car lowered?
I just bought a Milano and the center hub cap are missing. My wheels are the speedline, does anybody know where to find those?
Thank you.
The tires are 195/55/15 Toyo R888R and yes the car was lowered. I purchased the new rear springs and torsion bars from Rob at Centerline.
Jeff
Hi Joe, what size tires and brand did you use?
Pino
1 - 18 of 18 Posts
