Finally got the new cylinder head to replace the cracked head in my 1986 Spider. So I'm replacing the cracked 1986 2.0L head which uses a solenoid operated VVT cam with a 2.0L head which had mechanically operated VVT.
My understanding is that the solenoid operated VVT cam will drop in where the mechanical VVT sat, as long as I use the newer cam cover.
My question is: do I use the cam shaft caps from the old head or new? How about the tappets/followers? Use the ones on the replacement head or the old ones?
Duke
Duke
