Greetings,
Where can I obtain technical data specifically around the dimensions of the clutch plate to be used in the mechanical clutch setup? Reason for asking, I had my clutch plate resurfaced and it is definitely too “thick”. Tightening the bolts on the pressure plate to fasten it to the flywheel, makes the facing area where the release bearing interfaces, “sink away” – The car will surely not clutch.
I just had the sorry case for a gearbox redone from A-Z, dog gears, syncro rings, drums, bearings, seals ext, and don’t want to put it though the abuse it had due to a bad clutch or just plain bad driving habits.
Anything I should lookout for? What must I pay careful attention to when it comes to these mechanical clutches? Any pointers will be greatly appreciated!
