Hey Everyone--
I'm trying to do a master brake cylinder change and I'm running into a bit of a problem. (1991 Alfa 164L w/ABS)
I'm trying to follow Alfa Steve's directions, but "braking" the seal on the master cylinder seems to be a problem. Is it this hard?
I removed both 13mm nuts and star washers.
Removed both my 11mm brake lines-- that go to ABS unit.
I pull and pull on the master cylinder and its not moving...
Is it possible the previous owner (Mike the mechanic moron) used some adhesive to hold the master cylinder to the booster?
Or is there something I'm missing?
