1 - 20 of 43 Posts
Nice car. A couple of questions:
1 - How does the pedal feel with the brake boosters removed?
2 - What is the process for programming the fuel injection?
1- I have a boosterless setup with the same Alfaholics calipers. It's certainly a firm feel, but great modulation. I don't find the braking force to be inordinately hard.
2- Can't speak to this ECU specifically, but most aftermarket ECUs have software you can load onto your laptop that will interface with the ECU. You have a table for timing and fuel that you can adjust as you see fit. Most also have some sort of autotune feature for fuel that will read from a wideband 02 sensor and adjust fuel to keep AFR in a defined range.
Moderator
Discussion Starter · #6 ·
The guy dropped some serious coin on it! 💰
$87,500 ........
  • Wow
Reactions: 1978alfa
Moderator
Discussion Starter · #12 ·
140!
Is that a record, even outside of BaT?
Seems like too much, even if he did spend close to that on the car building it...
And the hand brake linkages are installed upside down ...
Well, come on now Pete.... what do you expect for $140K ?! 🤭
For better or worse, I believe BaT has been more responsible for the rise in GTV prices than anyone - and top level 2 liters seem to lead the market. With so many followers (over 700k now), there are a lot of well-heeled buyers out there and all it takes is two. That said, I wouldn't be surprised if the seller had that much in it. That Alfaholics stuff adds up fast!
1 - 20 of 43 Posts
