The Marelli Plex ignition on my Giulia Sprint has stopped producing a spark at the coil.
I checked to see if power was getting to the ignition module and it was (12 volts) so I replaced the module and the pickup cable. I also replaced the high tension lead from the coil.
Still no spark so I replaced the Marelli Magnetti coil with a Bosch MEC 723 which has slightly lower primary resistance but as the module is no longer under the coil I'm hoping this won't be a problem. I also replaced the wires and connections between the coil and the ignition module.
There is still no spark coming from the high tension lead so I am at a loss as to what to try next.
Any suggetions?
Any suggetions?
