21 - 27 of 27 Posts
Interested also Mark. I used LED headlights on my Porsche 356 and they were cheap and are absolutely brilliant. I fitted them myself after a lot of research. On the GTV 4-light models the low beam is the one to work on initially for me.
NOS Carello’s look nice too. I have 100/55 H4 bulbs, heavier wire and relays in my ‘66. Bulbs where purchased from Daniel Stern Lighting.
Can you elaborate a bit on how your did your wiring? Did you run heavier wire from the fuse block+relay+lights or just from the relays to the lights? Also what gauge wire did you use? I'm thinking of removing the perfect glass from my original Carellos and using them to replace the plastic "Carello" lenses that come with replacement 7in headlights.
21 - 27 of 27 Posts
