1 - 1 of 1 Posts
Hello Alfisti,
Previous year I replaced all rubber hoses on my Spider in an effort to hunt down a petrol smell. Unfortunately the problem still exists. Now I wanted to replace two hoses I skipped last year: the clear hose to the MAP sensor and the clear hose running from the Charcoal cannister to the EVAP tank. The question is now what hose should I use? I was thinking just regular PVC clear hose, but I am not sure to what extent it is a problem that regular PVC is not suitable for fuel?
Then another question I ran into while removing the passenger seat. I found one spacer underneath the seat rail. I thought there should be two? Am I correct in thinking that there should be a spacer underneeth each of the two bolts on the door side?
Thanks in advance for your advice.
Niels
1 - 1 of 1 Posts
