Still going through my stash of 164 (collected for years and years) parts and came across this sender for manual trans. The wires were barely holding on right where they enter the top of the sender, actually one was broken off completely. Of course these are getting scarce so I want to save it for somebody to use. I dugout the brown material at the top and found the wires are crimped (only) to the wires inside the sender. No solder there on the crimp ferrules or wires at all. Could explain why these sometimes can become intermittent. I am going to put it back the way it was made and just crimp them back (The engineers must have a reason for why it was made this way, maybe just so the plastic doesn't melt if soldered). What have others here done to replace the brown seal at the top? I was thinking of 5 minute epoxy or Lexel sealant.
Do check on your car that the wires are ZIP TIED to the body of the sender, that way the wires will not be stressed and fatigued by engine movements or repairs around the sender. Of course this can only be done if you have enough extra wire slack. AND remember folks (word of warning!) to never ever remove these manual trans senders by removing the small allen bolt or you WILL drop the plastic gear into the differential and you will have to remove the diff cover to retrieve it. Remove it by the 22mm bottom nut only. Does anybody need a sender? I will sell it for $30 plus shipping. Of course money back if it doesn't function.
I have two (or three actually) complete manual transmissions (with upgrade roller input bearings) as well if anyone needs one and misc manual trans parts.
Happy New Year Y'all! Take care
Charles
Charles
