Hello everyone, let me start out by saying that I've laid dormant for a while, because of a move to Florida, and back out to California again, a motorcycle accident, and some good old fashioned procrastination - but it's good to be back. Anyway, I have a '86 GTV6 from my father that has sat neglected for a while. The car has a few problems, that are as follows:
1. Car leaks oil (well, all italians do), but the cause is the rear main engine seal going bad.
2. Camshaft Seal Bearings need replacing, and this COULD be the cause of my next problem.
3. Just put in new spark plugs and I have a "fouling" at the third cylinder, the spark plug is wet with oil. (I don't know why)
4. The middle doughnut for the drive shaft needs replacing.
5. There's some minor rust around one of wheel wells, and in the rear trunk - around the spare.
All in all, these cars aren't worth much, but I don't want to part with the car I have, because it was my fathers' car. Also, the car only had one owner before him, it's red on black, the interior is VERY clean, it's an '86 with 90k miles, and what's the alternative... an e36 m3? They're nice, but I could see myself outgrowing one and becoming bored with my purchase, pretty easily.
I was thinking that the mechanical problems I'm faced with could be expensive so my questions are as follows:
1. Is it possible to replace the seals mentioned above (both rear engine and camshaft) without taking the engine out? or is it a relatively lengthy, time and money consuming process?
2. I think the cause of the wet spark plug could be the bad camshaft seals, but I have no idea. Any guesses as to what could be going on?
3. The rust and doughnut are easy and cheap fixes (I could do that myself), but if the other problems with the seals and sparkplug may not be. My thinking is that IF I will spend a good few thousand in labor/parts and be paying a mechanic to work on my car anyway, I should consider putting a new engine in. So, any guesses on the difficulty/cost of replacing the seals and fixing the sparkplug?
I thought the natural choice for an engine swap would be the milano verde. I have decided I don't want to go the route of forced induction. I don't have much money to spend, but if possible, a 164 engine would be a great one stick under the hood. I've seen 24v conversions like cchan's around here, and while I would love to do a conversion like that, I just can't afford it... So.....The last question I have is, is the 164 12v engine a much easier job than the 24v? i.e. - my happy medium between the relatively easy verde swap, and the more complicated 24v swap? or should I stick to the verde engine because it's just the easier more cost effective option?
I hope all this made sense, I am just trying to explain my way of thinking to everyone of the forum. I want more power under the hood, want to fix the problems that are there, either by overhauling the existing engine, or replacing what's there with something better, if it doesn't break the bank.
Also, ideas or speculations on hp and torque gain (in all scenarios: overhauling existing 2.5, a 3.0 verde, or a 164 3.0 12v) would be appreciated...
