1 - 1 of 1 Posts
Hello guys,
I have a 1999 146 1.4 T.Spark and just found out that both my main brake lights are not working, while the additional 3rd brake light strangely still does. After I replaced both bulbs, I was unpleasantly surprised to find that the two main brake lights still don't work.
Unfortunately, I am unable to find information as to which fuse and relay are responsible for the brake lights. One user manual excerpt I found online says that the fuse is the 8th from above on the left (15A), and that the same fuse also controls the 3rd brake light. If that is true, then it would mean the fault is somewhere else.
Do you have any advice on what I have to check? Thank you in advance!
1 - 1 of 1 Posts
