1 - 9 of 9 Posts
Hi,
Are the main bearings and Thrust washer on a 2.0ltr TS the same as the nord 2.0 engines? As I believe they share the same crank?
Cheers
Chris
Hi Chris,
Yes, main bearings are the same on both engines, and yes again, early TS and Nord share the same crank.
Jorma
Hi Chris,
Jorma
Great thanks. Silly question but how will I know if I need over sized bearings or just standard ones?
thanks
Chris
depends on the thickness of your crank, if it will get machined, thickness will be taken off and you will need oversize bearings ;)
Use plastigauge between the old bearings and the crank to check clearance. This should tell you if you need to go oversized or can stay with standard size shells.
Regards,
Lawrence
I think the best way is at first measured the crank, if it isn't worn out you can use new bearings in the same size as they were before.
Note, you can't use oversize bearings with unmachined cranksaft, if the crank is worn out you need go to machining shop, they worked it on and tell you what size bearings you need. Jorma
Is there any way of know if the crank needs machining? Twin spark engines done 70K miles.
Chris
70K miles isn't so much for the Alfa crank, I think it should be okay. Anyway, it isn't expensive at all let the guys of machining shop check the crank, after that you don't need think about it anymore! Jorma
1 - 9 of 9 Posts
