Uncle hasn't made a career of installing wiper motors...up until now. After hours of chasing blown fuses, paying dearly for rebuilds, and bending the ears of every expert I know across cyberspace and cellular air waves I can now report with certainty there is a God.
The most important thing I learned is there are six ways to connect wires to 3 poles--1,2,and E and there is only one correct one that will operate the wipers, park them, not blow fuses, and burn your house down. The caveat is the ONE way depends on whether your system is POS or NEG ground. They are not one and the same wire connections but are exclusive to each. Please read the attachments in entirety. They are priceless documents. I hope this clears up the misconception that Lucas makes junk and that they are built with shorts in them. Praise God!
"Per common tradition, reassembly is the opposite of disassembly. Maybe
clean the grease off before you put it back in the car. When it's back
together you can test it by applying power + and - to terminals 2 and E
respectively for negative earth, or + and - to E and 2 respectively for
positive earth. Connect terminal 1 to E to make it run. Disconnect terminal
1 to allow it to park. Rotate round cover to set the park position. Park
position will be slightly different running free vs under load, so this may
require a small re-adjustment after installation. " MGAguru.com
Special thanks to Les Hurlock and be sure to open the two attached sites. The MGAGURU is a master of instruction and entertainment
Wiper motor rebuild
MGA fused ignition circuit, wipers
Wiper motor rebuild
