L S D
GTV6PASSION,
You have initiated a great thread that has been expanded into specific details with information from some people having real world experience:
1. While there is nothing wrong with spending the $ for new discs, I think it is clear that two new discs in a stock setup will only produce the 21% lockup as specified for new cars. Your initial question has been highjacked into the topic of modifying LSD's for more lock up.
2. Jim K. has stated that new discs will wear faster than a LSD set up with used discs, but mentions the "pre-load" that can be acomplished by adding shims.
3. Richard Jemison recommends using an additional two discs and shims, but cautions against using pre load, and identifies undesirable consequences.
4. Richard also discussed the attractive lure of changing ramp angles, and advises against this.
Great stuff, everyone. Thanks...please keep the information flowing.
GTV6PASSION,
Richard you seem to have a bit of experience what is you take of new LSD vs "rebuilding" used ones. Is the cost saving worth not getting new?
