First Post Long Time Reader
1980 Spider Stored For 20 Years Close To Perfect
Stereo Stolen Hence The Wiring Problem
Idiot Light Wires Cut Or Disconnected. Figured Out Most Of Them
Car Has Not Been Drive But Runs And Starts Easily Have Cleaned All Wire Grounds And Connections .
What Is Wrong Low Fuel Pressure Light Does Not Work. Fuel System Gone Thru Like New . As I Understand The Circuit If The Sensor Light Is Grounded The Light Should Come On. (it Does'nt). The Light Works If Power Is Put To The Sensor Wire (dont Understand This Because No Ground).there Is Power To The Light Via A Pink Wire And Green/white To The Sensor On Fuel Filter For The Ground.
My Question Is Why Does The Lamp Light When Power Is Applied To The Sensor Wire When There Is Already Power To The Pink Wire .how Is This Circuit Completed Any Help Will Be Appreciated
Alex
Alex
