This car has had electrical related ignition issues since I bought it, but I really felt that I had them all solved.. So imagine my surprise when I started losing power on I94 and had to get a tow back home (about 3 miles away or so). The RPMs dropped slowly, so I realized after the fact that it must have been fuel related.. So I opened up the tank and lo and behold, the stepped hose. I never thought it would happen to me but now I realize that until Tuesday, I had never run this car with less than 1/2 a tank of gas! New parts ordered, I'd say it was a successful stress test in the heat - engine temps were pegged at 185 ish for the entire 2+ hrs I was driving around.
1690164
Vehicle Automotive lighting Automotive exhaust Gesture Yellow
I have the chunk that came off, in case you were wondering.
I had the same thing happen on my 85 Spider. Never ran it below half tank, til one day I did, on the freeway in Oakland, when it started sputtering. Luckily, offramp right there and a gas station. Filled up, drove home. Took the unit out, found just what you did. Not the greatest design; these all fail in time, in my experience.
View attachment 1690164 View attachment 1690165
That will do it every time. Glad you still have the bracket that goes around the fuel pump. I have seen pumps slide off of that hose without that bracket even with hose clamps
odd the hose looks so destroyed and yet the pump looks almost new (with perfect zinc plating, no signs of corrosion at all....)
was it a correct stepped hose you think? or does it look like some (non submersible) fuel hose jammed in there?
I carry a spare stepped hose in the trunk (along with enough stuff to get most broken down S4s back up and running if I came across one on the side of the road..)
Discussion Starter · #6 ·
It might look worse than what it really was because I picked at it a bit. It does look correct though, and I have to think its all original too. The tank is crystal clear, so I wasn't expecting much rust in and around the components. Even the sock was not super dirty.
I find humor in the idea of trailering a spare spider in case my primary spider breaks down =).
Being completely ignorant about later model Spiders, out of curiosity I did a little search on the issue, and was completely surprised to find that the stepped hose appears to be on the output side of pump. So how does it work with a broken hose at a half-full tank and above? Does the main pump have enough suction to draw fuel from the tank on its own? And if so, why does it need the in-tank pump at all?
yes, main pump can draw fuel on its own (eventually it will struggle, make wierd noises and then fail)
under 1/2 that hose is not submerged and the main pump sucks air, then fails
alfa recognised a problem with the injected cars where the 'pick-up' was on top of the tank and sent out a TSB to add the in-tank pumps to existing cars (thereafter the in-tank was added at the factory)
