1 - 2 of 2 Posts
As I strip my 99.7% rust free 1974 GTV down for paint, I found the expected rust around the front window (caused by the trim chaffing on the metal). The area includes about 1/2 of the driver A-pillar and about 40% of the lower lateral section.
I looked but didn't find anyone making a replacement panel for this area.
Does anyone know where I might be able to buy repair metal for this area? Or does the shop have to hand make new sheet metal?
Also, there was one very small 2nd area around one of the screws that holds the sill trim to the rocker. It was rusted thru in about a 1/2" area. The silver lining is that I could see into the rocker cavity and confirm there's actually no rust in the rocker structure itself. I think when I put it all back together, I'll use a sealant to hold the sill trim on, and glue in fake screw heads.
1628384
Through the years in the earlier cars, Alfa had some trouble with dissimilar metal galvanic corrosion. Many Alfas with metal window trim often ended up with galvanic rot where the trim was fastened to the body metal. The rest of the car could be perfect. That problem went away when rubber molding was used to hold the window in, or when they started gluing the glass in to act as a structural member of the chassis.
1 - 2 of 2 Posts
