what are the spec for the 2 bolts that are at the front of the head down at the block? the big ones are easy to find specs on, but can not find them on these 2 smaller bolts.
doing a re-torque after a head swap and can not find what the spec should be on them
cheers
use the normal torque chart for the bolt size and grade. Since they dont seal the water jacket etc its less critical. I typically use 25 ish ft/lbs as I recall?
